Sorry, its a complete new build (my old PC I built 5 years ago and shes being put to sleep)Im confused, are you buying a complete new build or upgrading an existing?
Taking into account the new monitor and the editing, this spec, slightly over at £2550 once factoring in the 3080, would be an editing monster (probably overkill for your editing uses):
CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
AMD Ryzen 9 3900XT 12 Core CPU (4.7GHz/70MB CACHE/AM4)
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
Firefox™
Home Installation
Heatsink GPU - P955RT3
Price: £1,759.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/kNzNsXJSvg/
Based on just about everything I've read, it's a change well worth making 👍Super thanks for the advice. I've always gone with Intel so using AMD will be a change for me.
