Not sure if my graphics card will fit in this build.....
Goodjacky
Hi all :)
I'm looking to get a new compact PC while still using my graphics card. But I'm not sure if it will fit in this case as I've heard many concerns about this...
Furthermore, is the cooling going to get in the way? Is a 550w Power supply enough for this?
My Graphics card:: https://www.overclockers.co.uk/evga...press-graphics-card-gx-304-ea.html#tech_specs
Many thanks for your help
FRACTAL DESIGN NODE 304 Mini ITX Case
Intel® Core™ i5 Six Core Processor i5-9600K (3.7 GHz) 9 MB Cache
ASUS® PRIME H310i PLUS R2.0: Mini-ITX, LGA1151, USB 3.1, SATA 6GBs
16GB Corsair VENGEANCE DDR4 2400MHz (1 x 16GB)
1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
NOT REQUIRED
CoolerMaster MasterLiquid Lite 120 High Performance Liquid Cooler
GIGABIT LAN PORT + Wi-Fi (Wi-Fi excluded on H310I-PLUS)
NO RECOVERY MEDIA REQUIRED
Price: £790.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-sff-gaming/pcBgXfYwF7/
That doesn't seem like a very balanced build. What are you using the system for? gaming? specific games? non-gaming uses?
And if you're on a tight budget, why the £50 spend on slightly faster delivery?
It should fit the GPU, I'm just not sure about whether any of it is the best thing to buy, depending on your use case :)
Goodjacky
Thanks for the reply :)
I have my reason for the faster delivery, and the portability is very essential for me :/
My main use will be for video games. What improvement would you suggest?
Not buying an Intel i5, not buying a trash tier motherboard, not buying slow single channel RAM. Instead, R5 3600, B450 mobo, dual channel high frequency RAM. And buying an SX6000 SSD instead of the QVO (on a mobo that doesn't bottleneck it either). And if it's a mini ITX system buying a modular PSU.
But it's hard to say without knowing your uses as asked above :)
