Hi there, basically I need your guys help. I'm not entirely sure this rig I've customized can run certain FPS's like Farcry 3 and soon to be released Crysis 3 on ultra/high settings, I play other games such as GW2 but that's not major. I'm keeping this set up affordable but still capable of handling ultra settings (with some settings turned down) or everything on high, at least that's the aim.
My specs are;
CPU
Intel® Core™i5 Quad Core Processor i5-3570K (3.4GHz) 6MB Cache
Mobo
RAM
GPU
2GB NVIDIA GEFORCE GTX 660 - DVI, HDMI, VGA - 3D Vision Ready
HDD
Network card
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs (Even though Mobo has WIFI integrated, should I downgrade?)
PSU
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Only provided the core elements, nothing else is really required to be said.. I think.
My specs are;
CPU
Mobo
RAM
GPU
HDD
Network card
PSU
