No signal to monitors on computer startup, plugging monitors into other GPU fixes it?
bigben
Master Poster
I've got SLI GTX670s with 2 monitors.
Usually the only way I can get signal on the monitors is having them plugged into the GPU at the bottom. However, this morning I booted up and everything posted as usual, I tried plugging the cables into the GPU on top and it's working fine.
Does anybody have any idea why this has happened? It's not a massive issue, but it's a bit of a pain having to pull the desktop out from under the desk. Thanks
mantadog
Superhero Level Poster
Have you checked you are still running in SLI mode?
If it's happened all of a sudden then it could be a failure of some sort, though other than that I cant think of anything.
bigben
Master Poster
Definitely still in SLI mode, that was the first thing I checked as I updated new drivers yesterday and sometimes forget to enable it again.
Still getting decent performance as well. No idea why that's changed all of a sudden though, odd.
Does your bios specify the gfx output? I'm not familiar with sli but I know in the old days you could specify which card controlled output.
