Newer build
PC.Robb
I recently posted a build on the forums but I'm deciding to get a bit more :D check it out.
*Pc purpose, mid/high end gaming*
The reason I'm changing is I want it to last me a while, So I changed the processor and motherboard since after reading from a few sites intel core i5 2500k is awesome.
Old build here:http://www.pcspecialist.co.uk/forums/showthread.php?8995-Thinking-of-buying-mid-range-gaming-PC.
Intel® Core™i5-2500k Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
1GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
Free Item
FREE Batman Arkham City with any Nvidia® GeForce GTX560 or above!
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Price: £904.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/mainstream-intel-sandy-bridge/
DanteWilhelm
OK, that's the same as mine
remember the K variant of the processor is for overclocking
if you're not going to be overclocking just get the i5-2500 which will save you money
but yeah looks good! and I would say that because it's almost what I ordered xD I don't have it yet so I can't tell you what it will perform like
PC.Robb
Yeah K version is the unlocked version right, I might be doing some overclocking would you recommend upgrade the cpu cooler?
tom_gr7
Life Serving
yes, defo up the cpu cooler if overclocking. have you considered a amd spec? you could get a very good setup for 900quid with amd!
tom_gr7
Life Serving
What ya think of this? Comes in at £883
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE - great case, ya could stick with the t900 if you really want that one or if ya wanted to save a few quid.
AMD PHENOM II X4 970 (3.50GHz/8MB CACHE/AM3) - BLACK EDITION - excellent quad core cpu, could be overclocked
ASUS® M5A87: AM3+ PLATFORM, DUAL DDR3,SATA 6.0GB/s, USB 3.0
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (2 x 4GB KIT) - great ram, was only a quid more than the samsung version.
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable - excellent gpu for gaming! Great price!
CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£86) - great psu, if you ever wanted to add another gpu in the future for upgrades, ya would need a 1200 psu.
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER (£19) - great cooler, but go for the titan if you wanna overclock, also think about if you do go for the titan, its massive!
3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour) - forgot to add the warranty for a fiver, dont forget that lol.
hope this helps
Teaz
You can still overclock without the 'K' variant i5 but to not big crazy clocks as the 'K'. You wouldnt really need to overclock it to high clocks for gaming, standard stock clocks are fine or if you want you can overclock it a little further. I recommend dropping the K variant and the high speed ram for perhaps a higher gpu like a amd 6950 or gtx 570.
you cant go wrong with either amd or intel :) both will have no problems managing games with fine a decent build.
PC.Robb
I Upgraded to the Titan Fenrir evo one. Also I upped the power supply(corsair) from 650 to 750, not much but If i'm overclocking I beleive I would need more power, About the HD6970, Isn't the gtx 560 ti better becuase In the near future I plan to add another gtx 560 ti to my system, I'm also sticking with the ram becuase as you say it's only 1pound more than samsung. If I could get the same budget with a amd spec I might aswell go for a core i5, I've read reviews that it's alot better and faster than amd cpu's.
The price Of the system now with a few changes is £923 including vat&delivery.
PC.Robb
also, swap the 1600mhz ram to 1333mhz ram as 1600 is only needed when OC'ing!
There is a 1 pound difference between 133mhz memory and the 1600mhz memory so I might aswell spend a extra pound and get the 1600mhz in case I decided I want to overclock.
Teaz
The amd 6970 and 6950 will beat the gtx560Ti pretty much any day even if you Crossfired them, they will very likely beat an SLI 560Ti.
indeed an intel is better than amds current lineup but the price difference goes towards them. amd's good cpu range will provide plenty of power for gaming.
Petchi b
Agreed!
And Tom's spec above is spot on, I'd go with that.
