Hi there, I've been checking over the past few months, and I have noticed that you do not seem to update the current watercoolers you have.
Is there any reason why you aren't using any of the Corsair h** Watercooling CPU coolers in your possible builds? the temp difference is very noticeable, especially when overclocking.
I hope someone can reply, I want to buy a new computer with one of these corsair watercoolers if possible, without having to fit it myself. It would be very ideal if you could stock or even just be able to put them on you're custom built pc.
thanks, Craig.
BTW my computer i bought last year is fine. It works perfectly, I just need a second computer.
thanks, Craig.
