New to PC building, any bottlenecks/advice on things to change?
hxgth
My proposed build is as follows:
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
64GB Corsair VENGEANCE DDR4 3000MHz (2 x 32GB)
1x 120mm Thermaltake TOUGHFAN 12 Case Fan
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Standard Build - Approximately 16 to 19 working days
Price: £2,948.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/45DMyjs5Mf/
Budget, although not extremely strict is around £3000, but the lower the better
I have one 4k 144hx monitor and another 1440p 144hx monitor.
This build will be used for gaming primarily but also for streaming / video editing as well as creating and rendering large 3d graphics projects.
I would much prefer to build a pc myself but with all the supply issues and limited know how i thought this to be the best bet.
Just wondering if this build has any major flaws that should be addressed
Many thanks everyone :)
PS. Im not too sure about the sound card, wireless network card and usb/thunderbolt options and how they affect the build.
Bigfoot
Grand Master
What is your maximum budget? Please provide the unique configuration link, so that we can easily suggest some changes
Steveyg
If you want all singing all dancing mate this is where I'd go
If you really want that £3k budget limit I can work this down but this is about as close to the top as it gets
ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
64GB Corsair VENGEANCE DDR4 3200MHz (4 x 16GB)
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
Corsair H115i RGB PRO XT Hydro Series High Performance CPU Cooler
NOT REQUIRED
Price: £3,169.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/hQJpD0vPhY/
hxgth
NOT REQUIRED
Yeah this looks brilliant. If imma go for high end might as well go full high end. Would the cooling be okay on this with no extra fans? also can i ask why the two smaller ssd's not one bigger one? just curious
Steveyg
on the drives the 500GB drive is for the OS and key programs. This drive should never be more than 50% full to ensure fastest OS speeds possible
Second 1TB M.2 SSD is for all files where loads times can be improved by a fast drive. Fill this up to your hearts content
The 3TB HDD is for general storage and anything that doesn't require fast load times. I stop at 3TB because anything larger has abysmal speeds at 5400RPM which is dreadfully slow these days unless you go Iron Wolf which are server rack drives and very loud
The extra fans shouldn't be required. The case comes with 3 fans and the CPU cooler comes with two and a radiator so temps will be fine. More wouldn't cause an issue but aren't required
hxgth
Ive been doing a bit of research on this case and apparently the temps can reach quite high figures, also the hdd drive is in a suboptimal place next to the power supply so the cables wont allow anything to be in it. Are there any good swap outs to avoid these problems?
In my humble opinion, the range that PCS offer at this level is a little thin.
You do have the option to order a case from elsewhere and just put the delivery address as PCS with your order number on it as advised once you order the system stating "have my own case".
For your requirements you want something quite excellent at cooling potential. I'm not sure what your requirements are for RGB aesthetics or where that comes in your priorities?
The case that always springs to my mind for this kind of level of build, is the Lian Li PC011 Dynamic. It's a superb case, both aesthetically and performance wise. It's got a separate compartment for cabling and drives and is a pleasure to build in and cable manage.
It comes in Black or White or a Razer Edition in Green with RGB Strip down the front.
Thing to note is that it doesn't include any fans, but you'd have 2 x 140mm fans on the cooler on the roof, then just add a further 3 pack of corsair LL120 fans from PCS and get PCS to build them into the side panel that goes into the secondary compartment.
You don't need a rear extractor fan believe it or not, although there's no harm in adding another 120mm
I have an earlier model of a very similar case called the PC09 which I bought in 2014, and I'll be using it for my next build as well, it fits all the areas I'm keen on.
hxgth
NOT REQUIRED
When going ahead with this build it says it only needs a 750W supply rather than a 1000W one. Does this higher wattage offer any advantage? or shall i downsize
Steveyg
You don't build for what you need now you build for what you might need in 5 years time, the idea is to have enough room to power everything comfortably and have enough headroom to make upgrades and add components
The higher wattage will also allow the build to run quieter and cooler. There is no downside to have a large PSU
