New Spec review
stesco
My current computer has reached its last legs so need to invest in a new computer. Just looking for any thoughts before I take the plunge and complete the order. I use my computer mainly for X-Plane 11.
THERMALTAKE V200 TEMPERED GLASS RGB EDITION GAMING CASE
Intel® Core™ i9 Eight Core Processor i9-9900K (3.6GHz) 16MB Cache
ASUS® ROG STRIX Z390-E GAMING: ATX, LGA1151, USB 3.1, SATA 6GBs, WIFI - RGB Ready
11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready!
Corsair H80i V2 Hydro Series High Performance CPU Cooler
Promotional Item
Get Just Cause 4, PUBG & More w/ select Intel CPUs!
Promotional Item
Get BFV AND Anthem AND Metro: Exodus with select NVIDIA GeForce RTX GPUs!
Welcome Book
Price £2,584.00 including VAT and Delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/5YFVRwBgsj/
That's a fair fit for the GPU
I'd recommend a better case with more airflow. The Corsair Crystal 460x would be a good choice
The H100x cooler is more effective and not much more expensive, though for the i9 I'd ideally get the H115 and an appropriate case to fit it.
The 3TB HDD seems to only be £11 more so I'd probably get that
Cool, glad it helped. Let us know how you get on with the spec once it reaches you, if you have the time :)
