New PC system and ordering review
weare one
03/07/18 pc ordered after much help from forum. A big thank you to all especially Oussebon.
11/07/18 email from PCS:- system is in processing
27/07/18 07.23am email from PCS:- system has been built and is awaiting testing and configuration.
27/07/18 10.51am email from PCS:- make sure monitor is connected to dedicated GPU and not M/B integrated graphics
27/07/18 10.51am email from PCS: system has been dispatched, with details of DPD tracking which was excellent.
01/08/18 08.46am email from DPD saying item will be delivered today between 12:06 - 13:06
01/08/18 12:38pm delivered.....I am sooooooo happy.
Unfortunately:-
1). The CD player was not working.
2). The case rear fan was not working.
3). The led strip light was not working.
To cut a long story short and 3 days of emails to PCS and much searching on my part:-
1). CD player power connection not connected correctly.... easy push in fix on my part.
2). The case rear fan wiring not connected at all.....took a while to trace wiring via taking off back side panel and following wiring loom to find junction connections not connected.
3). The led strip light was actually not connected at all......eventual easy fix, though had to lift the end of the self adhesive strip as case stud was preventing connection when end of strip was laid flat and the 4 pin connection could not connect. So now the end of the strip is laying loose over the case stud.
Overall the system arrived very well packed, although I personally believe it may have been this internal packing that may have pushed down on the led strip connection forcing it apart ?????
As for the usually strong cd power connection fitting ?????????????
And the rear case fan connection in the wiring loom????????
The case is not all lights and whistles but as I am not a gamer.......I love it ........and the pc system itself boots in seconds and just flies through applications :punk:
NZXT PHANTOM 410 WHITE GAMING CASE
Intel® Core™ i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
ASUS® PRIME Z370-P: ATX, LGA1151, USB 3.1, SATA 6GBs
4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
1[SUP]st[/SUP] Hard Disk
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
1[SUP]st[/SUP] M.2 SSD Drive
500GB SAMSUNG 970 EVO M.2, PCIe NVMe (up to 3400MB/R, 2300MB/W)
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler
LED Lighting
50cm Blue LED Strip
WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
Windows 10 Multi-Language Recovery Image - Supplied on DVD
Firefox™
LOGITECH® MK270 WIRELESS KEYBOARD & MOUSE COMBO
Price €1,629.00 including VAT and delivery
they must get this all the time :)
Fair review, good photos.
weare one
Thanks Oussebon
I must say this system is now running sweet......but there again I was previously running a system built around an auld Asus P5W DH Deluxe m/b which I must admit was well overdue for an upgrade but has undoubtedly served me well.
If this new system serves me as well (and I am sure it will) I will be more than happy :yes:
Thanks Oussebon
[FONT=&]I must say this system is now running sweet......but there again I was previously running a system built around an auld Asus P5W DH Deluxe m/b which I must admit was well overdue for an upgrade but has undoubtedly served me well.
[/FONT][FONT=&][FONT=&]If this new system serves me as well (and I am sure it will) I will be more than happy :yes:[/FONT]
[/FONT]
Nice balanced system overall, I’m sure you’ll be very happy with it! That blue led strip is damn effective! I might plump for a few of them.
My rig is on an old z87 platform and I’m getting very itchy to upgrade the mobo, cpu and ram. I think I’ll do it with the 9th, and probably go for an i9 as I want hyperthreading.
weare one
My rig is on an old z97 platform and I’m getting very itchy to upgrade the mobo, cpu and ram. I think I’ll do it with the 9th, and probably go for an i9 as I want hyperthreading.
Yes I think the led strip looks cool.
Now that I've got this new baby I'm going to play around with my old P5W DH to see what I can get out of it.
I've already got a Q6600 chip, relevant bios upgrade chip will be around £10 plus cheap memmory upgrade from ebay and see what happens.
The case is a huge Kandalf LCS, which was given to me years ago fitted with the m/b so fingers crossed I can replace the cpu without messing up the liquid cooling part of the system :yes:
