New PC spec any thoughts
BloodBeast
Hi Guys
Im thinking about having this this spec built.
I will be using pc for burning 3D DVD's and high end gaming
any ideas and advice would be most welcome thanks
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Overclocked CPU
Overclocked Intel® Six Core i7-3930K (3.2GHz @ max 4.6GHz)
ASUS® SABERTOOTH X79: SOCKET 2011, R.O.G
16GB KINGSTON HYPERX GENESIS QUAD-DDR3 2133MHz X.M.P(4 x 4GB KIT)
120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79)
INTEL CERTIFIED LIQUID CPU COOLER FOR SOCKET LG2011 (£79)
Fan Controller
NZXT Sentry 2 Fan Controller with upto 5 Fitted Case Fans
Asus Xonar DG 5.1 SoundCard & Headphone AMP (Award Winner) (£20)
Genuine Windows 7 Ultimate 64 Bit - inc DVD & Licence (£139)
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9)
Price: £2,243.00 including VAT and delivery.
AwesomeDude
Looks Good But I'd suggest you Lower down that Cpu to a 3820, Because Gaming does Not Utilize the Overclock on your Cpu and As for Burning 3d Movies the 3820 should be good!
Heard Good Things about that Sound Card Btw I suggest you keep it :)
AwesomeDude
Yea You could up it too That, However that Cpu will Destroy whatever your doing even without the Overclock so I suggest getting the Titan Fenrir So that You can Overclock quite a Bit but not Insanely! :)
Corfate
Can't see any room for changes :) Possibly upgrade the PSU so you can SLI another 680 later on if you fancy :)
And yes, that soundcard is amazing :p I have one myself :)
