New pc - fitting my own gtx 780 in. Thoughts?
Bsrz
Rising Star
Hey all what do you think of this spec - going to fit my own gtx 780 in it. - what do you think about this build in terms of upgradability, size and performance once I add my 780 in it.
Intel® Core™i5 Quad Core Processor i5-4460 (3.2GHz) 6MB Cache
ASUS® Z97-A: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
Free Item
Free Item
ASUS ECHELON Gaming Headset ***ASUS PROMO***
8GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (1 x 8GB)
1st Hard Disk
120GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 410MB/sW)
500GB WD CAVIAR BLACK WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
CORSAIR 750W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (£89)
INTEL STANDARD CPU COOLER
Quantity 1
T
TheGeeza
Silver warranty for £5 and triple copper heatpipe cooler.
Bsrz
Rising Star
Gigabyte motherboard, i5-4690 and a non-quiet case.
Hey Keynes, any reason in particular as to why I should get the Gigabyte mobo insted of the ASUS® Z97-A board?
if I was to buy the Gigabyte mobo I would go for the Gigabyte Z97X Gaming 3
thanks.
also is there a big difference between the i5 4460 and the 4690? im just trying to keep costs down a bit.
thanks.
why the z97x? are you planning to SLI? the gigabyte motherboard is cheaper and it will perform as well as the asus board gaming wise, it allows you to upgrade other bits in your spec like the cpu.
Bsrz
Rising Star
Not sure about SLI, its a possibility. can you not sli with the Gigabyte board?
I though you are downgrading from SLI, considering is for a 2nd rig I don't see why you would consider a motherboard that supports SLI. If that's the case you need to upgrade the PSU as well.
Bsrz
Rising Star
you are correct I am downgrading from sli - but in the future I might sli again depending on if I have some spare money.
for now tho 1 gpu will be enough so based on your suggestion I will go with the gigabyte board.
