new pc,constant high cpu temps
psychollama
my pc is 2 months old and is running fine as such but my friend noticed the cpu is constantly at 65-70 degrees even idle and after googling most say it should be sitting around 30-40,i will say im a computer novice so im not sure if this could cause long term problems?it doesnt seem to go a lot higher playing games,ive noticed it at about 70-75 when i check after playing a game.
FRACTAL MESHIFY 2 LIGHT TEMPERED GLASS
Promotional Item
Get Avatar: Frontiers of Pandora™ with select AMD products. (C)
ASUS® TUF GAMING X670E-PLUS WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
12GB NVIDIA GEFORCE RTX 4070 Ti - HDMI, DP, LHR
CORSAIR iCUE H115i ELITE CAPELLIX XT RGB High Performance CPU Cooler
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Promotional Item
Microsoft® Edge
Often when people think the system is idle, it's actually running quite high demand background tasks.
Downloading things for instance can have very high CPU useage as it actually decrypts and extracts files while it's downloading.
The only way to be certain of loads is to run a full 100% load for about 10 minutes with Prime95, have HWMonitor open from just before you start the test and then take a screenshot of the CPU readings at the end of the test WHILE the stress is still running
