New PC concerns
Wolfram74
Hello I just bought new PC from PC Specialist (build bellow).
I am really happy with it so far, however I have 2 concerns at the moment.
1.My PC has this beep noise when i start it up, I googled the signal meanings but cant quite understand what it is. (LINK HERE) skip to 16 seconds.
2. Although PC has liquid cooled CPU, it does not have any case fans (on top or at the back) (image attached). Now when i check sensors temp - looks quite ok, playing NFS HEAT some parts goes up to 60C-80C case it self gets quite warm, which i guess is normal? My question here is weather should I look to get some case fans installed at all?
Many thanks for your support!
Here are my specs:
Case CORSAIR 175R RGB MID TOWER GAMING CASE
Processor (CPU) AMD Ryzen 9 3900X 12 Core CPU (3.8GHz-4.6GHz/70MB CACHE/AM4)
Motherboard ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
Memory (RAM) 32GB Corsair VENGEANCE DDR4 2666MHz (2 x 16GB)
Graphics Card 6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
1st Storage Drive 3TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
1st M.2 SSD Drive 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
Power Supply CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Corsair H115i PRO Hydro Series High Performance CPU Cooler
Wireless/Wired Networking WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
Windows Recovery Media Windows 10 Multi-Language Recovery Image - Supplied on USB Drive
Office Software FREE 30 Day Trial of Microsoft 365® (Operating System Required)
Browser Microsoft® Edge (Windows 10 Only)
Keyboard & Mouse PCS S300 USB MEDIA KEYBOARD
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
Insurance Simplesurance Purchase Protection inc. Accidental Damage & Theft
Build Time Standard Build - Approximately 15 to 18 working days
Welcome Book PCSpecialist Welcome Book - United Kingdom & Republic of Ireland
Most PCs beep when you turn them on as it is a signal from the motherboard to say that everything hardware-wise has checked out and the system will continue booting...if it beeps more than once then it indicates a problem.
Yes, it's the POST beep. It's there to tell you the PC completed the POST process ok.
Wolfram74
Thank you, however there are 4 more beeps after that 1 initial beep. If you see the video link attached and forward to 16 sec, you will hear it
Wolfram74
As to cooling, can't say I'm entirely surprised as that is not the best case for cooling....for a build your level, you would have wanted a more premium case. However, actual temps are okay depending on which bit it is...GPUs can handle into the low 80s max and CPUs can go quite high as well. If it was me, I'd be looking to add a rear exhaust fan as well as a second front fan....won't fully solve the temps but it may be enough to bring them down a bit
Thank you!
I am quite new to building PC's
Not sure what to do now, i fell like i should send it back in and upgrade for bigger case with fans?
what case would you recomend?
many thanks
Thank you!
many thanks
The beep codes represent a GPU issue, but it's actually quite common on some motherboards when the monitor is connected with an HDMI cable and the monitor is in standby when the PC powers on.
Try connecting a DP cable and boot again, see if the beeps go away.
Temps are all fine.
Deleted member 17413
One long three short beeps i heard, isnt that something to do with the RAM?
Try powering off, including the PSU/socket on wall and take the RAM out and reinsert.
Edit:
Different per board and not as standardised as I thought...1 long 3 short is def GPU on your motherboard, not RAM
As for the case...
Fans for the cooler sit on its radiator, which will be inside the case attached to the roof normally.
I dont think you will see the fans for it in that case... did no one help you with your build?
Wolfram74
Temps are all fine.
This makes sense, because of my HDMI, i noticed it sometimes does not beep, because monitor is already on.
Much appreciated !
Wolfram74
As for the case...
I though I read enough info online. My bad, still not sure what to do, any recommendations?
Well, its already been built, so you cant really change the case lol.
I would look at getting 3600MHz RAM though, should never have gone for less than 3200MHz with the curernt AMD's they are much better with higher frequencies.
