New pc build
MorNun
Im building my dream PC for gaming, twitch, music production and some data analyst work/ai. Any thoughts ? My budget is around 4500 and aiming to max out my 4k 144hz monitor, thinking of a 5080gpu or 90 if in budget. I need a lot of storage for games and data.
Thanks!
CORSAIR iCUE 5000T RGB MID TOWER GAMING CASE
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
ASUS® ROG CROSSHAIR X870E HERO (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE DDR5 6000MHz (4 x 16GB)
16GB GIGABYTE GEFORCE RTX 4080 SUPER WINDFORCE V2 - HDMI, 3 x DP
8TB CORSAIR MP600 PRO NH NVMe PCIe M.2 SSD (up to 7000 MB/R, 6100 MB/W)
8TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler
ASUS XG-C100C V2 10 Gigabit PCI-E CARD (1 x RJ45)
Microsoft® Edge
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Common Pack Large
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/nzcesZw6KK/
I would wait for the 9950X3D if you really want all those cores. There's nothing you have mentioned that really merits it though. The 9800X3D would be more than enough for your uses. Analysis may make use of the 32 threads, but you would need to be using very thread heavy processes for it to make sense, I'm guessing you will know better. Noone knows the complexity of the 9950X3D yet, the 7950X3D had some issues recognising games, which would sometimes require some manual intervention to use the 3D Cache CCD for optimisation. If you don't have a specific need for the core heavy chip then the 9800X3D is definitely the go-to, you would need to feed back though.
Other than that, you have the budget to get everything top end. I wouldn't look at the 5090 though, waste of cash. Double the price without giving you anything tangible on your monitor. Save the £1k for the rest of the build or towards the 6080 which will definitely give more performance for likely the same £1k investment.
The build you have selected looks slightly trollish. Don't take offence, it just looks like someone has gone in and maxed the options. This is either someone who doesn't know what they are doing but has a good budget so thinks max price is best choice....... or trolls come on just to mess around. I'll presume innocence at the moment and try to make sensible recommendations than maxing out your wallet. Ironically, some things that don't matter are massively over-specced where the PSU and cooling are drastically under par, 2 of the most important considerations in a build completely overlooked for some bling in unimportant areas.
The case you have chosen is a beauty and I'm not adverse to it. With that being said if the 5000X case was available, I would be going down that route. I've seen them side by side and the 5000X is nicer looking IMO, although the T does have an air of quality to it that is very slighly lacking on the X by comparison.
I've opted for a more sensible storage layout but if you can give some clarity on what you were thinking I can adjust.
So.... buiild. I wouldn't change much of this for myself even if I had a lottery win in honesty.
4080 Super is a placeholder for the 5080, should be similar cash. Just kept it in to show the costing.
64GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 32GB) AMD
16GB ZOTAC GEFORCE RTX 4080 SUPER TRINITY BLACK EDITION - HDMI, 3 x DP
1TB CRUCIAL T705 GEN 5 M.2 NVMe PCIe SSD (up to 14,500MB/sR, 12,700MB/sW)
4TB CORSAIR MP600 PRO NH NVMe PCIe M.2 SSD (up to 7000 MB/R, 6500 MB/W)
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Price: £3,558.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/VrjQNzJnYE/
