New Pc Build
goethe
Hi guys, this is the spec for the pc i will be purchasing next month. Please tell me what you think, and any improvements would be great :yes:. I plan on addiing a second 7970 in a few months/
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
Overclocked CPU
OVERCLOCKED AMD FX-8150 (3.60GHz @ max 4.5GHz)
ASUS® CROSSHAIR V FORMULA: AM3+, 3-WAY SLI/CROSSFIREX, ROG
16GB KINGSTON HYPERX GENESIS DUAL-DDR3 1866MHz X.M.P(4 x 4GB KIT)
3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR
COOLIT ECO II FAT BOY PUSH/PULL CONFIG LIQUID CPU COOLER
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence
Wozza63
Biblical Poster
You will be much better off with a 680 imo, it beats the 7970 in pretty much everything and is well worth the extra money, you will also only need the 750w modular (if you want) to run this system
if you dont need anything specific on the current motherboard you can drop it the the M5A99X Evo and save a lot of money, it has SLI etc
EDIT: Also, drop to the 1600MHz RAM you won't notice a difference, and you will only need 8gb for gaming, my PC has barely gone above 4GB when gaming so I have 4GB doing nothing but its always there just incase
