New pc, advice welcome
Cuv360
CORSAIR 4000D RGB AIRFLOW TEMPERED GLASS GAMING CASE
Promotional Item
AMD Ryzen 9 7950X3D 16 Core CPU (4.2GHz-5.7GHz/144MB w/3D V-CACHE/AM5)
ASUS® TUF GAMING X870-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 32GB) AMD
24GB GIGABYTE RADEON™ RX 7900 XTX GAMING OC - 2 x HDMI, 2 x DP
2TB CRUCIAL T705 GEN 5 M.2 NVMe PCIe SSD (up to 14,500MB/sR, 12,700MB/sW)
External DVD/BLU-RAY Drive
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Price (Ex VAT)
£2,534.17
Price
£3,041.00
Order Quantity
Bulk Discount
£0.00
Total Order Price (Ex VAT)
£2,534.17
Total Order Price
£3,041.00
Estimated Weight
15.854kg
P/O Number
Edit P/O Number
Payment Method
Maximum Required Power
548W
As hinted at by @Martinr36 , we'll need to know:
  • What it's being used for (be as specific as you like, but if it's a split of uses we'll need to know what is the most important)
  • What is your MAX budget
  • What monitor(s) is it being paired with (make & model, or resolution, refresh rate, response time, panel type, etc.)
  • What are your aesthetic preferences (if any), regarding case colour, side, shape, glass/mesh, RGB, etc
  • ...and of course we'll need the WHOLE config, including the price and config link (to avoid us having to start a new config from scratch)
But in general, I'd say you've got a lot of the bases covered. Just need to swap the PSU for a modern ATX3.1 one (1200RMx Shift), remove the replacement thermal paste (as the pre-applied Corsair stuff is better), consider rejigging the storage allocation (1TB, 2TB, 2TB or 1TB, 4TB maybe), and maybe consider a slightly larger 5000 series case so that stuff isn't crammed in.
Cuv360
Edited original post with pricing.
1 : Primarily gaming, reason being I've had 11 years out of my last computer, which is using a gtx 960 4gb card. So I fancy something with better specs. Last time I bought a computer I'd say it wasn't even mid tier.
2 : £3k ish have capacity to stretch If needed
3: AOC Gaming CQ32G2SE - 32 Inch QHD Curved Monitor, 165Hz, 1 ms MPRT, VA, AMD FreeSync Premium, Low Input Lag, Speakers (2560x1440 @ 165Hz, 250 cd/m², HDMI/DP)
4 : black case, monitor etc not fussed on rgb but not averse either
Originally picked 1200w power supply but changed to 1000w after the pcs recommendation.
Will find a new case that's bigger.
What do you think for the storage configuration.
Cuv360
I also do some 3d designs for 3d printing but I don't use professional software. It's hobby level designs etc. That's just some further info
