New Monitor
Potatoguru
Hey just posting to see if people think it's worth upgrading my monitor to go along with my new PC.
This is the monitor i currently have, a 1440p 60Hz 27 Inch Monitor from Acer:
And this is my new PC build:
NZXT H500 MID-TOWER GAMING CASE (BLACK)
Get 3 Months of XBOX Game Pass for PC w/ select AMD Ryzen CPUs
Gigabyte X570 GAMING X: ATX (USB 3.2 Gen 2, PCIe 4.0) - RGB Ready!
Get Control & Wolfenstein: Young Blood w/ select GeForce RTX GPUs!
1TB INTEL® 660p M.2 NVMe PCIe SSD (upto 1800MB/sR | 1800MB/sW)
Cable Management
3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
Thanks!
What's the budget for the upgrade?
You could get something with a high refresh rate and some form of adaptive sync. It would be appropriate for the spec, and improve the gaming experience,
Potatoguru
Want to keep it as low as possible ideally, is there anything worth buying that's around £200? or would it be better to just stick with my current monitor at that budget?
Your current monitor costs a little over £200, which is normal for a basic 1440p monitor.
You're not going to get much of a meaningful upgrade on that for less money :)
It's not like GPUs where every year or two you can buy something better for less cash, monitor prices don't change much.
Potatoguru
Alright thanks, i'll just stick with the monitor I've got then :) I am keen to try out gaming at higher refresh rates though but i'll wait until my monitor gets a bit older.
