New machine
Zredarb
Hey guys,
So I'm in desperate need of a new machine, as my current machine (from PC Specialists) has just turned 7 years old!
I will be using the machine for gaming mainly, looking to get as much bang for buck as I can around £2K. I've had the below build off a couple of friends, but wondered if you guys who really know your stuff notice anything or have any suggestions?
Thanks in advance!
FRACTAL MESHIFY C BLACK GAMING CASE (Window)
Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
ASUS® ROG STRIX Z390-E GAMING: ATX, LGA1151, USB 3.1, SATA 6GBs, WIFI - RGB Ready
8GB ASUS ROG STRIX GEFORCE RTX 2070 - HDMI, DP
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
500GB SAMSUNG 970 EVO M.2, PCIe NVMe (up to 3400MB/R, 2300MB/W)
NOT REQUIRED
Promotional Item
Get Call of Duty: Black Ops 4 & More w/ select Intel CPUs!
Promotional Item
Get Battlefield V with select NVIDIA GeForce RTX GPUs!
Price £2,062.00 including VAT and Delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/9X78x2EJR4/
You can definitely do better in terms of value for money and frankly raw performance for the cash.
What monitor are you using?
Are you planning to upgrade that? If so, when, and with what budget?
Zredarb
I am planning on upgrading to a 144hz monitor from my standard 60hz 1080 I have, prob spend a few hundred on that.
Thanks for your help! I'm a real rookie at this.
stegor
Unless you need the onboard wifi, then I would switch to the Gigabyte Aorus pro. It's £58 cheaper and at least as good as the Asus.
Zredarb
Cheers! I was told to aim for Asus motherboard, but this is just as good? I won't lose anything then?
Thanks again
stegor
Thanks again
The Gigabyte board fits your build fine. You could use the saving to upgrade your second drive to the 4TB Baraccuda.
Probably something along these lines as my 1st monitor, with a standard 180p as my second.
https://www.amazon.co.uk/Dell-S2417...i-Glare/dp/B01KZIOSSQ?ref_=fsclp_pl_dp_2&th=1
This is a 1440p 144hz monitor with gsync, and is the sort of thing you should indeed be looking at for this budget.
Graphics Card8GB ASUS ROG STRIX GEFORCE RTX 2070 - HDMI, DP
The Asus 2070 is almost £200 more expensive than the regular 2070. An RTX 2080 is less than £70 more. The Asus cards almost always have an insane markup, and this is one of the most egregious examples of the so-called Asus Tax. Don't buy the Asus 2070 - or any Asus GPU - at this kind of price difference.
Processor (CPU)Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
An AMD R7 system would be better value. In that it's £200 cheaper, and makes no meaningful performance difference at 1440p. To back that up:
Your spec £2062, and equivalent R7 Spec: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-pc/ss5XmBphyz/ £1905 (still including the Asus 2070 for fairness ofc.
While performance:
Edit - see the charts at the end of the post. Forum just is not letting me have them in line today.
Not really any meaningful difference there.
So maybe something like:
AMD Ryzen 7 2700X Eight Core CPU (3.7GHz-4.35GHz/20MB CACHE/AM4)
Gigabyte X470 AORUS Ultra Gaming: ATX, USB 3.1, SATA 6GBs - RGB Ready
---Get an AMP500 Gaming Mousemat w/ select GIGABYTE Motherboards!
16GB Corsair VENGEANCE DDR4 2933MHz ~ (2 x 8GB)
8GB NVIDIA GEFORCE RTX 2080 - HDMI, 3x DP GeForce - RTX VR Ready!
---Get Battlefield V with select NVIDIA GeForce RTX GPUs!
1[SUP]st[/SUP] Storage Drive
1[SUP]st[/SUP] M.2 SSD Drive
NOT REQUIRED
Price £1,969.00 including VAT and Delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/amd-am4-pc/rVF49!vAjk/
