Vortex Series: 15.6" Glossy Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-3630QM (2.40GHz) 6MB
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
NVIDIA® GeForce® GTX 680M - 4.0GB DDR5 Video RAM - DirectX® 11
1TB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
SSD CACHE DRIVE
120GB Kingston SSDNow mS200 mSATA (upto 550MB/sR | 520MB/sW)
GIGABIT LAN & WIRELESS INTEL® ADVANCED-N 6235 (300Mbps) + BLUETOOTH
Firewire
1 X 1394a FIREWIRE PORT
1 x UK Power Lead & 180W AC Adaptor
Genuine Windows 8 64 Bit - inc DVD & Licence
DVD Recovery Media
Windows 8 (64-bit) DVD with paper sleeve
INTEGRATED BACKLIT UK KEYBOARD WITH NUMBER PAD
Mouse
Dead Pixel Guarantee
30 Day Dead Pixel Guarantee Inc. Labour & Carriage Costs
Hi all! New member here. I ordered a Vortex 3 as above today. Originally wanted a Haswell (Optimus V) but reckon paying a bit more for the Vortex 3 with better GPU. Vortex 4 with Haswell is out of budget for me unfortunately :sweatdrop: .
As I ordered an mSATA SSD + HDD, keeping the optical drive, I just want to know whether the OS will be default installed on the mSATA SSD or not? Tried to see if I can put a note in the 'set partition' on the order but I only have option for the HDD.
If the OS cannot be installed on the mSATA SSD, I reckon I will have to change the spec and opt for a normal SSD + HDD in optical drive caddy instead. (Still early days in the order process so possible! :yes
Any advice appreciated! Thanks!
SSD CACHE DRIVE
Firewire
DVD Recovery Media
Mouse
