Vgillett44
Hi folks,
I'm getting a new gaming PC for the first time in 7-8 years and was hoping for any advice you might have.
I spent a week doing research online and speaking to my tech buddies and settled on this build.
As I said, it's primarily for gaming. I don't really care about ray-tracing all that much, I just want something that performs well at 1440p. I already use a Viewsonic-XG2703 monitor, but I'm not sure if I will need to get a new monitor for this build sincee it is also 7-8 yeras old now. Or I could simply get a second monitor so I can browse the internet or do work while I'm gaming.
I know it might be slight overkill, but I want something that can deliver a great high-end gaming experience and that I won't need to think about upgrading for several years.
The main things I'm unsure of are the motherboard and processor cooler. Any advice on these would be much appreciated, although all advice is useful.
My Budget is between £2500-£3000
Thanks.
FRACTAL NORTH TG XL GAMING CASE (BLACK)
Promotional Item
ASUS® TUF GAMING X870-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
24GB ASUS TUF GAMING RADEON™ RX 7900 XTX OC - HDMI, 3 x DP
4TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
2TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
1 x 120mm Thermaltake TOUGHFAN 12 Case Fan
ONBOARD 2.5Gbe LAN PORT
Firefox™
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/dfKbDMyzJw/
Thanks.
Promotional Item
Firefox™
