Zenith
Hello all,
So my current PC is starting to get a bit behind the times, being around 4 years old. I considered going through the process of upgrading it, but as a lot of the components would have to go, and as my knowledge of doing it yourself extends only so far, a completely new build is probably the simpler - if not more expensive - option.
I spend most of my time on games, and I prefer to run them on the highest settings - and performance - possible. My current system has just about managed to keep up, but after playing the PlanetSide 2 beta for a while, I started to realise that it was going to get ugly in the next year or so (chug, chug, chug).
So, without any more rambling, have I got it right? I'm a bit behind with the current tech, so advice is welcome.
Thanks,
Zenith
COOLERMASTER HAF XM - GAMING ENTHUSIAST CASE + USB 3.0
Intel® Core™i5 Quad Core Processor i5-3570K (3.4GHz) 6MB Cache
8GB KINGSTON HYPERX GENESIS DUAL-DDR3 1866MHz X.M.P(2 x 4GB KIT)
240GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
SPIRE GEMINI REV.3-THERMAX HDT TWIN FAN CPU COOLER (£39)
Fan Controller
NZXT Sentry 2 Fan Controller with upto 5 Fitted Case Fans
Asus Xonar DGX 5.1-Channel Gaming Audio Card (£25)
Price: £1,359.00 including VAT and delivery.
Thanks,
Zenith
Fan Controller
