New Elimina Laptop Review
[email protected]
My 6th PC from PC Specialist.
Like all the others this does not disappoint. Arrived well packaged with planety of charge in battery to get it up and running with no real preparation.
Elected to have an NvMe SSD with 16GB Ram to run Windows 11 so a snappy start and set up was just a case of running through the usual Windows Stuff.
Lovely vibrant screen, very clear keyboard and good feedback from the keys. Large touchpad with integrated mouse buttons not separate buttons as per previous laptops. Responsive and easy to use. Thin bezel around screen make use of all screen footprint.
A full e manual is worth a read and explains everything you need to know. I needed to check that I did not manually need to load all the drivers on the enclosed DVD and was told this was already done.
Having got an external DVD I did not need an internal one so weight and thickness reduced accordingly.
Installed software I need for now without issues and all connectivity (Internet, wireless and Bluetooth) as faultless for me. A joy to use and very happy with the choice I made and the service from PC Specialist as always
