New desktop build
gorsmi
Anything I should upgrade / downgrade ?
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB Cache
ASUS® RAMPAGE IV EXTREME: INTEL X79, SOCKET 2011, R.O.G
32GB KINGSTON HYPERX BEAST QUAD-DDR3 2400MHz X.M.P (4 x 8GB KIT)
4GB NVIDIA GEFORCE GTX 680 - 2 DVI, HDMI, DP - 3D Vision Ready
480GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
INTEL CERTIFIED LIQUID CPU COOLER FOR SOCKET LG2011 (£78)
Fan Controller
AeroCool Touch 2000 LCD Touch Screen 4 Fan Controller + 2 x Front USB
2 PORT USB 3.0 INTERNAL PCI-EX CARD + STANDARD USB PORTS
3 Year Platinum Warranty (3 Year Collect & Return, 3 Year Parts, 3 Year labour) (£135)
sted
Rising Star
It depends on what your use for the machine is. But if anything I highly doubt you'll need much in the way of upgrades if any at all. In fact you could downgrade somethings that youve chosen and still have a beast of a machine.
gorsmi
Budget and planned use please. Do you plan to overclock? Do you plan to upgrade? How long do you want it to last?
Budget £3000
Planned Use: Business / home use, no gaming (can't stand slow machines)
Overclock: Yes
Upgrade: Probably not.
Last how long: 5 years min.
ilike2burnthing
Please expand on 'business and home use', what tasks will actually be performed and what software will be used? Gotta say, 3K for that just seems like a gigantic amount of overkill.
Toxophilix
Budget £3000
Overclock: Yes
I think you would get a better result from spending £1,500 now and buying another machine for £1,500 in two and a half years' time. Same expenditure but you would have a better computer at the end of the five year period (and, of course, the first machine could be sold, repurposed or cannibalised). I appreciate your point that you don't like slow machines. Neither do I. However, for £1,500 (or a lot less, actually) you can get a machine that will make standard-issue Windows business and home-entertainment software absolutely fly.
But if you could expand a bit on the type of programs you want to run then I think we can make some useful suggestions.
