New Build
gavcor
Hi All
Have a look let me know what you think
Case PCS MAELSTROM T900 BLACK GAMING CASE
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-960 (3.20GHz) 4.8GTs/8MB Cache
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card 1GB NVIDIA GEFORCE GT 430 - DVI,HDMI,VGA
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 1.5TB WD CAVIAR BLACK WD1502FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk 1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
3rd Hard Disk NONE
4th Hard Disk NONE
RAID NONE
1st DVD/BLU-RAY Drive 12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£48)
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
Processor Cooling SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER (£19)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
gavcor
The main concern i have relating to this is that im considering overclocking. Would you recommend a more suitable power supply as with the current setup should only be using around 365 leaving 85 spare for clocking. Any help appreciated.
Tracker
What's the pc's intended purpose? if you're going to overclock then you'd want a better than the triple copper, a Fenrir Evo would be a good choice. but again depending on what the use for the pc will be, you may not need or want to overclock at all!
gavcor
Sorry about the delay mate been a mental weekend. The machine is going to be used for a few things ill be setting the secondary drive up as my file server. The primary will be used for development work anything from Android to websites. So there may be some graphic design being carried out not a massive amount thou.
