Is the RGB strip plugged into your motherboard or does it have its own remote/similar?Hi, I got my build today and am very happy with it, but I cannot seem to find how to control the rgb strip that was placed with my pc? I have ICUE but it only detects the ram, motherboard and case fans? Is there something else I need to download?
It's plugged into my motherboard, I have checked the connection and it seems to be plugged it fine? it's plugged into the ADD_GEN2 slot I believe? I have the asus TUF B550 motherboard if that helps.Is the RGB strip plugged into your motherboard or does it have its own remote/similar?
It will be controlled with Armory Crate from here:It's plugged into my motherboard, I have checked the connection and it seems to be plugged it fine? it's plugged into the ADD_GEN2 slot I believe? I have the asus TUF B550 motherboard if that helps.
Thank you! now working.It will be controlled with Armory Crate from here:
I think that plugin only lets Armoury Crate control the RGB on RAM, not the RGB strips or fans.I've not used this myself so I can't vouch for how well it works, but I noticed that iCue have a plug in for Armoury Crate so that (hopefully) you can sync up all of your RGB:
How to: Integrate Armoury Crate with iCUE
With Armoury Crate, you can control the lighting effects of your Corsair Vengeance RGB Pro or Dominator Platinum RGB memory modules. Enabling Armoury Crate If you installed Armoury Crate before th...help.corsair.com
Completely normal.The frames and pc is running perfectly fine but in task manager it is running at 100% load on a game that isn't very gpu demanding (runescape 3) is there something I can change configure wise or is it normal and ok? Again i'm not experiencing any lag and the temps are perfectly fine (67%)
FWIW iCue will do the RGB 12V headers but not the ARGB 5V headers on ASUS motherboards.I've not used this myself so I can't vouch for how well it works, but I noticed that iCue have a plug in for Armoury Crate so that (hopefully) you can sync up all of your RGB:
CORSAIR iCUE 5000X RGB MID TOWER GAMING CASE - AMD Ryzen 5 5600X Six Core CPU - ASUS® TUF GAMING B550-PLUS - 16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz - 6GB NVIDIA GEFORCE RTX 2060 - 500GB SAMSUNG 980 PRO M.2 - 1TB INTEL® 670p M.2 NVMe PCIe SSD - CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLDThat's not great. Can you post your full build specs?
If you can post the full specs as in this link:Also an extra fan mounted above the gpu, which isn't branded I don't believe.
CaseAnd what cooler do you have?
