New Build PC
simmcn
Just ordered this today! Cant wait to receive it!
ZALMAN Z11 PLUS BLACK MID TOWER CASE
Intel® Core™i7 Eight Core Processor Extreme i7-5960X (3.0GHz) 20MB Cache
Gigabyte X99 Gaming 5: ATX, LG2011, USB 3.0, SATA 6GBs, XFIRE/SLI
8GB KINGSTON HYPER-X PREDATOR QUAD-DDR4 2666MHz X.M.P (2 x 4GB)
4GB NVIDIA GEFORCE GTX 970 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
2nd Graphics Card
1st Hard Disk
500GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
8x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
CORSAIR 750W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H60 Hydro Series High Performance CPU Cooler
DUAL-BAND WIRELESS 802.11N 450Mbps PCI-E CARD
1 x 1 Metre European Power Cable (Kettle Lead)
Genuine Windows 8.1 64 Bit - inc DVD & Licence
SlimCini
KC and the Sunshine BANNED
Please don't say just for gaming... Please don't say just for gaming... Please don't say just for gaming...
simmcn
Sorry SlimCini yep will be gaming rig but will also be using it for photo and video editing
I'm a massive flight simmer and Arma fan so will be getting the most out of them with this PC
SlimCini
Some odd choices there then. If editing was your reason behind that uber powerful and expensive CPU (which is entirely not needed for gaming) then why only 8Gb RAM? The amount of editing involved to justify that CPU must surely be something that would also justify at least 16Gb RAM, no?
And if gaming is the primary role, then why 2 x 970s and a 5960x? it would only be £40 more to have a 5940k and 2 x 980s which would be far better for gaming (although, again, totally unnecesaary or anything other than a 4k screen really)? And £100 less for a 5820k and 2 x 980s!
Just an odd choice of CPU, RAM and GPU combo.
simmcn
To be honest SlimCini, I had the money to spend on a future proof'd machine and I can always upgrade graphics card and memory later on, I was given the budget and read up on the 980 v 970 GPUs, and many of the articles said that if you can get 2 970s it will be a little bit better than the 1 980. I'm not fussed about the problems with the card where only 3.5Gb's are actually available at a time which will be hopefully sorted in the near future, but with 2 GPUs and the other components in the rig, it shouldn't make much difference with games and applications I will be using.
Cheers for the feedback too
