New build - how much VRAM do you recommend?
Gage
Hi all, I'm configuring a new build (32GB RAM) and am not sure how to go regarding the graphics card. I use photoshop, do video recording and editing, multi-tasking and may want to get back into 3D modelling and rendering in the future (I don't play video games though).
I was considering getting the Nvidia Geforce RTX 4080 Super (16GB), but can't decide if I'd be better off getting the 20GB PNY RTX 4000 or the 20GB AMD Radeon RX 7900 XT, so I have enough room for GB growth over the next few years if I need it. Or is more than 16GB overkill for what I need? I'm not sure.
Also would an AMD card be suitable for these kinds of tasks? I've always used Nvidia cards in the past, but AMD are cheaper, which would be helpful. I've looking at reviews and stuff, but it's not really helping me decide.
Thanks!:)
Thanks!:)
For professional use, NVIDIa cards still have quite an advantage to AMD with the tensor cores
The appropriate card much depends on your maximum budget and what suites your working with for editing/rendering and 3d modelling
Gage
Thanks. Suites would be like Substance, blender or Silo, maybe other stuff like Terragen. But frequent use of Photoshop for sure, which seems to hog quite a lot of resources on my current PC.
I wouldn't worry too much about Photoshop, it's the least likely to hit a wall with the GPU. 16GB would be massive overkill for Photoshop but for your other uses it's a good shout.
The next generation of GPUs is around the corner. I would also get advice on the system as a whole, rather than selective queries. We often see people go down similar avenues with builds that we try to avoid.
Some information and guide to what we need to suggest some builds:
Gage
Thanks Spyder.
So here's the current configuration I'm looking at. My reasoning is to have something that's going to last for a while and allow for increased RAM and VRAM requirements for applications in the future/other upgrades. My current build gets slow and choppy now when I've been using Photoshop for a bit (documents with lots of layers and file size), and trying to multitask. So I want something that can handle that.
I also need a good amount of storage space (again, mainly because of photoshop docs with lots of layers), but I may do my video creation and editing on the desktop instead of my latptop, and other creative tasks, so that will eat up space.
Looking at the post 'Why more than one storage drive?' has been helpful, so I'm thinking the SSD for the OS (2TB or 4T?) and 6TB hard drive for creative/video software and document storage (or should the creative/video software run on the SSD? ) and then buy a separate external hard drive as a secondary backup for that.
I'll add a second monitor I already have too.
It's quite expensive (for me). I would rather have kept it below three grand, but can spend a little more to get the right specs that will last.
So my questions are:
- Do you think this build is suitable or overkill? Should I increase/decrease any of the specs?
- Also, which is better: Corsair or Samsung SSD? (I've seen a lot of bad reviews for both online:( )
- And Vram, should I go for the Geforce16GB or PNY 20GB (I've always used Geforce in the past but it doesn't have a 20GB option).
SPEC:
LIAN LI LANCOOL 205 MESH C GAMING CASE - WHITE
Intel® Core™ i9 24-Core Processor i9-14900K (Up to 6.0GHz) 36MB Cache
ASUS® TUF GAMING B760M-PLUS WIFI II (mATX, LGA1700, DDR5, PCIe 5.0, Wi-Fi 6E)
64GB PCS PRO DDR5 4800MHz (2 x 32GB)
20GB PNY NVIDIA RTX 4000 ADA GENERATION, 6144 CUDA CORES 4 x DP
4TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
6TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
CORSAIR 650W CX SERIES™ CX-650 POWER SUPPLY
PCS FrostFlow 150 Series High Performance CPU Cooler
2 x 120mm PCS Black Case Fan
ONBOARD LAN PORT
I'd recommend staying away from Intel, as you'll never adequately cool it, and will have to run it at reduced power to stop it breaking.
I believe the RTX4080 / 4080 Super is about 50% faster than the RTX4000 ADA in rendering (in fact the only 2 GPUs that beat the 4080 are the 24GB RTX4090 and 48GB RTX6000 ADA, and if the 5080 is about the same price for 10% more performance it may be wise to wait for that instead.
If it were me, I'd be buying the PC without a GPU and waiting until the end of the month to buy a £979 RTX5080 from SCAN as soon as it's available (may be low stocks initially, so you'd have to jump on it as soon as you saw it).
RTX ADA comparison in content creation(same benchmarks, so you can see the difference in scores):
RTX 40-series comparison in content creation (same benchmarks, so you can see the difference in scores):
My £3k would go on something more like this (it's £2100 as I've excluded the GPU)...
CORSAIR iCUE 5000X RGB MID TOWER ATX CASE - WHITE - better case for thermals, and room for upgrades
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5) - the best AMD productivity CPU you'll get without going to a Threadripper CPU
GIGABYTE X870E AORUS ELITE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7) - latest motherboard platform with USB4 for very fast external drive/device connections
64GB Corsair VENGEANCE DDR5 6000MHz (2 x 32GB) KIT - upto 10% faster in Adobe benchmarks than the 4800MHz kit
NONE, I ALREADY HAVE A GRAPHICS CARD - either a reduced price RTX4080 Super or a new RRP RTX5080 Founder's Edition (once the new models are released at the end of the month)
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - small, fast drive just for Windows and your application installs
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W) - good value and fast secondary drive
8TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE - went up to 8TB as it's slightly cheaper than the 6TB, but I'd prefer the Ironwolf drive myself as it's an enterprise-grade drive, rather than a consumer-grade drive
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET - not needed if you went for the 4000 ADA model (could get away with the new 750RMe or 850RMx ATX 3.1 models), but for a 4080/5080/5090 then this will not be excessive
CORSAIR ICUE LINK TITAN 280 RX RGB HIGH PERFORMANCE CPU COOLER - latest offering from Corsair and will keep the CPU operating well within its optimum temp - and be quiet doing so (once a bit of fan profile tweaks have been done, as they're a bit aggressive out of the box)
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Price: £2,128.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Zg2Dm6um8A/
Meant to add that the desktop 4080/5080 would be better UNLESS you’re using software which only offers support for the workstation GPUs (as I know some CAD stuff is awkward like that).
Gage
Hi, thanks very much for your feedback and suggestions.
Some things I'm not sure about: doing some cursory research I've read that AMD's are not as good as Intel for raytracing, and intel are better for compatability with different programs, AMD aren't always compatible.
I've not ever tweaked a desktop CPU cooler, so not sure how I'd get on with that.
If I'm using the HDD for storage, and the 1st SSD is for the OS, what is the 2nd SSD best used for? Would it be best to install the OS on one SSD and run apps on the second?
The 13/14th gen Intel i9s were the best multi-core offering…until the Ryzen 7000 and more recently Ryzen 9000 series CPUs came along.
The problem with the Intels was that they’d start degrading the moment they were installed, and jus5 got worse and worse the more they were used, and would ultimately require replacement due to crashing. So much so that cloud providers were swapping out their Intel clusters to AMD clusters, and realising they were using about 50% of the power for the same performance, and didn’t require as much cooling.
Intel have released microcode updates to mitigate the degradation, but it reduces performance and only slows down the issue.
The 4TB SSD is simply there to replicate your original choice…but it’s not recommended to have all your critical files on the same single SSD as the Windows install, as you will invariably need to reinstall a corrupted Windows install at some point, plus it gives you another level of redundancy.
Tweaking of the cooler just means going onto the Corsair iCUE software and manually adjusting the fan speeds so they’re at a comfortable balance of noise/performance for your ears…we can help if you need assistance.
Think you're getting confused with CPU vs GPU, you're referencing AMD GPU's which for this kind of workload aren't as good as Nvidia. But in CPU workloads they're way ahead of Intel.
Not something you do.
For production systems, this is best practice for drive setup
  1. OS & Application files - Fastest NVME
  2. General documents/download files - HDD storage
  3. Project media (video, images, sound, etc.) - Fast NVME
  4. Cache files - Fast NVME
No matter how much RAM you have, you'll always offload to the cache, and for best performance you want this as a dedicated drive
