New build for 4k Gaming
ste3l
Morning all, just wondering what you guys all think about this spec for 4k gaming.
Case CORSAIR 175R RGB MID TOWER GAMING CASE
Processor (CPU)Intel® Core™ i5 Six Core Processor i5-10600K (4.1 GHz) 12 MB Cache
MotherboardASUS® PRIME Z490-P (LGA1200, USB 3.2, CrossFireX) - ARGB Ready
Memory (RAM)16GB Corsair VENGEANCE DDR4 3000MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP
1st Storage Drive1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
1st M.2 SSD Drive256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingPCS FrostFlow 240 Series RGB High Performance Liquid Cooler
Extra Case Fans1x 120mm Black Case Fan (configured to extract from rear/roof)
Sound CardCreative Sound Blaster® Audigy™ FX OEM
MrWilson
For 4K gaming an AMD CPU is definitely the way to go over Intel.
Your build could do with some other adjustments, got some questions for you so we can help advise further.
What is your budget?
What are your uses besides gaming? e.g streaming, editing, design
What monitor are you using or have in mind? Make and model or resolution and refresh rate would be handy to know. For reference the 3070 is a 4k 60hz GPU.
ste3l
and baring in mind i ordered this pc over 2 weeks ago so cancelling to change to amd would be a drastic hit
MrWilson
I appreciate that, but AMD is far superior in terms of performance and upgradeability. Right now I honestly can't recommend an Intel build. This is the AMD equivalent. This is as bare bones as I would recommend for 4k 60hz.
NZXT H511 MID-TOWER GAMING CASE (BLACK)
STANDARD AMD CPU COOLER
Standard Build - Approximately 16 to 18 working days
Price: £1,692.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/sCV9S0SaKC/
