New build check please.
Altissimus
Hey,
My computer is 4 years old so I think it needs a refresh. This is what I'm looking at.
Any cock-ups/improvements/suggestions?
A couple of points:
1) This rig only needs 443W and therefore could take a 450W PSU, but I wasn't sure of the quality of the stock 450W PSU offered. Is it any good?
2) 443W seems light...why so little?
3) I have no idea about the case. What's a good case these days for ~£80-100?
4) On a separate but related note, is nVidia 3D Vision any good? (I'm currently playing Elite:Dangerous, Smite, Far Cry 4, Borderlands Pre-sequel...)
Thanks all!
A.
Intel® Core™i7 Quad Core Processor i7-4790k (4.0GHz) 8MB Cache
ASUS® Z97-PRO GAMER: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
24GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (3 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
1st Hard Disk
1TB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (£69)
Price: £1,456.00 including VAT and delivery.
1) and 2) 450w will limit any future upgrade and the configurator is very accurate in calculating power requirements
3) I would suggest coolermaster 690 for a single gpu and the storm trooper if you are planning to sli
4) do you have a 3d monitor that supports nvidia 3d vision? It is great for movies and games
Is it just for gaming? 24gb seems a lot and if just for gaming unnecessary . Are you planning to SLI or overclock your cpu?
Altissimus
4) No. Thinking about possibly getting one if it's recommended.
No plans for SLI. Poor experience in the past (admittedly 5 years ago) and it seems an expensive way to achieve performance that can often be adequate with a single decent card. No plans to overclock. Does more memory not benefit gaming rigs, then? How much RAM would you suggest?
Altissimus
3) I would suggest coolermaster 690 for a single gpu and the storm trooper if you are planning to sli?
The 690 doesn't support the 52-in-1 internal card reader, and the Storm Trooper is £119 which is a lot of money for a case for this rig imo....any other choices?
The Storm Enforcer I originally chose - you don't rate it?
I think that depends on you since you know what your requirements are. I personally will go with the same budget you indicated for the case +£80
Altissimus
Wait, what? The case you recommended was £119...which wasn't my budget....I'm confused?!
Did I get the price on that wrong?
Altissimus
Sorry I meant the coolermaster for £79? £80 to £100
Yeah...I believe that one doesn't support the 52-in-1 reader, more's the pity.
Not sure how much diff the case makes, to be honest. Might just look at one of the other ones.
If you are planning to add a 2nd gpu I would go with a full tower case with better cooling and forgot to suggest silver warranty for £5
Altissimus
Keynes, I appreciate your input but you don't appear to actually be reading what I say. So don't worry about it, I'll go check out the cases myself and try and find some objective reviews on the interwebnet.
Thanks anyway.
