New 4090 Build
Kaney
Really just wanted to build a pc that would do me for the years to come and wouldn’t struggle with anything that’s thrown it’s way. I think everything here should be perfect but my knowledge on pc building isn’t the greatest.
CORSAIR iCUE 5000T RGB MID TOWER GAMING CASE
AMD Ryzen 9 7950X 16 Core CPU (4.5GHz-5.7GHz/80MB CACHE/AM5)
GIGABYTE X670E AORUS MASTER : ATX (WIFI 6E, USB 3.2 Gen 1, PCIe 5.0) - ARGB Ready!
32GB Corsair DOMINATOR PLATINUM RGB DDR5 6000MHz (2 x 16GB)
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
4TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 1600W PRO SERIES™ TITANIUM AX1600i DIGITAL MODULAR PSU
1 x 1.5 Metre IEC C19 UK Power Cable
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler
4x Corsair LL120 RGB LED Fan + Controller Kit
Microsoft® Edge
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Welcome Book
Logo Branding
PCSpecialist Logo
Price:£5,420.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/wy5VVkEynS/
B4zookaw
Clearly money no object 😂
Personally, I’d pick Asus over Gigabyte when it comes to motherboards, so I’d switch to the crossfire. And up the warranty from the standard one.
What do you mean when you say anything you throw in it's way? Rendering? Databases? Gaming?
While the 7950x is a wonderful productivity chip, it's not so great for single threaded tasks and will actually reduce performance.
Kaney
My job involves a lot of rendering and I’m also an an avid gamer. So it’ll be a work computer and also my go to game computer.
Kaney
Thankfully not 😂
It is ordered so I’ll keep the motherboard but will 100% upgrade the warranty, thanks for the advice my friend.
Steveyg
Thankfully not 😂
You can change the parts at any point before it goes into building mate, would strongly recommend an ASUS board over Gigabyte they just have better build quality, better support, better drivers, etc
Gigabyte are not what they used to be
Kaney
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/aNJy6ptzHm/
Will be here Monday. Will update you with pics
