New 1080p build for purchase in December approximately
Lockstar
I plan to game a lot on this build and also do rendering work on programs like Maya 2018 and Unreal Engine 4.
NZXT S340 MID TOWER GAMING CASE (BLACK/BLUE)
AMD Ryzen 5 2600X Six Core CPU (3.6GHz-4.25GHz/19MB CACHE/AM4)
ASUS® PRIME B350M-A (DDR4, USB 3.1, 6Gb/s)
1st Hard Disk
1TB SAMSUNG PM961 M.2, PCIe NVMe (up to 3000MB/R, 1700MB/W)
NOT REQUIRED
Corsair H100i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
Genuine Windows 10 Home 64 Bit - inc. Single Licence [KK3-00002]
CoolerMaster Devastator III Combo Keyboard and Mouse
Price £1,289.00 including VAT and delivery
Questions
1. Is a 1TB SSD overkill even if my total of games on Steam add up to more than 471GB (other platforms will push it to over 500GB most likely) or should I keep it and reduce the HDD space (maybe from 3TB to 1TB?)?
2. Is the CPU cooler a bit over the top for a 2600x or is it fine?
3. Which graphics card would be suitable to buy with this build, or is it worth waiting for new cards, such as NVIDIA's cards coming this summer or future Vega cards from AMD?
Thanks a lot for your help!
There's not much point planning a build so far in advance as all the hardware will be different / better by then and prices will be different.
It's fun experimenting with the configurator in advance of buying, I'm sure we all did that. SpyderTracks is right though, it's way too soon for anyone on here to offer meaningful advice because everything will likely have changed by December. :)
To answer your questions...
If you can afford the 1TB SSD and the 3TB HDD then stick with that config, you can always partition the SSD later and give yourself a blistering fast data drive as well. If the 1TB SSD is pushing the budget somewhat then a 512GB M.2 NVMe SSD and a 3TB HDD (or bigger) generally offers the best balance between price and performance.
I'd have thought it's a bit overkill personally, a decent air cooler will be fine I'd have thought.
I'll leave it to others more knowledgeable than I on these things to comment. Chances are that by December there will be something new on the near horizon...
Lockstar
Thanks! Yeah, I mostly experiment with the configuration and share them just to get better ideas of certain components :p
