Need To Lower the Price of this AMD Bulldozer Spec. Plz Help
BigC
Choose Your Own Case BitFenix Colossus Venom
AMD BULLDOZER EIGHT CORE FX-8120 (3.10GHz/8MB CACHE/AM3)
ASUS® M5A97: AM3+ PLATFORM, DUAL DDR3, SATA 6.0GB/s, USB 3.0
2GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
500GB SEAGATE Barracuda SATA-III 6Gb/s HDD, 32MB Cache (7200rpm)
COOLIT ECO II A.L.C ADVANCED LIQUID COOLER (£59)
2 x 200Mbps HomePlug AV - Create a Wired Network Using Electric Sockets! (£38)
Monitor
IIYAMA E2273HDS 24" LED WIDESCREEN, 2HDMI/DVI-D 1920x1080 (£159)
DVI-D & HDMI Monitor Cables
1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£8)
LOGITECH® K200 USB MEDIA KEYBOARD (£10)
Surge Protection
6 Socket Compact 2M UFO Surge Protector (£9)
Price: £1,043.00 including VAT and delivery.
Need To Lower The Price by about £50 but dob't know what to get rid of??????????
Configure Here: http://www.pcspecialist.co.uk/computers/amd-bulldozer-top-spec-pc/
NMEBowen
Master Poster
drop the coolit down to the titan thers £20, do you need the card reader another £5, 2 inches of screen just sit closer another £20, do you plan on using more than one screen if not drop the 560ti down to the 1gb version thats £30, not sure but the screens should come with the needed cables so the hdmi shouldnt be needed thers another £8.
hope these suggestions all help.
BigC
Thanks for the advice, i'm now buying a cheaper monitor from amazon and I removed the Card reader, however i'm going to keep the HDMI Cable as amazon don't provide cables, I am also keeping the 2gb graphics card tbh for future-proofing and I'm getting a full HD monitor.
colleydog
hd 6950 2gb
Hey if your using high end monitors and multiple monitors, i would recommend the HD 6950 2gb as it's a bit more powerful and £2 cheaper.
Wozza63
Biblical Poster
you will only need 1GB =, thats not really futureproofing, the overall power of the GPU will be a bottleneck well before the memory on the card, only if you are using 3 monitors will this be any use, even when you have 2 monitors you wont be gaming on both
