Need Help With Motherboard options and cooling for gaming PC
Kiiavahr
Hello,
I'd like some suggestions with what the better options for the motherboard, and sufficient CPU cooling options would be for this build please.
This will be a purely gaming PC
I have currently a 2560 x 1440 monitor also.
Budget £2000-2700
CORSAIR 3500X ARGB TEMPERED GLASS MID-TOWER (WHITE)
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
Get Monster Hunter: Wilds with select AMD Ryzen™ Processors!
64GB Corsair VENGEANCE DDR5 5200MHz CL40 (2 x 32GB)
16GB GIGABYTE RADEON™ RX 9070 XT GAMING OC - 2 x HDMI, 2 x DP
2nd M.2 SSD Drive
PCS FrostFlow 240 Series ARGB High Performance Liquid Cooler - WHITE
LED Lighting
2 x 35cm Corsair LS350 Aurora RGB Light Strips
5 x Corsair ICUE LINK RX120 RGB PWM Fan + Controller Kit - WHITE
ONBOARD 2.5Gbe LAN PORT
We can't give you any advice until you tell us what it's for (and some other info as detailed below)...but you seem to have just copied someone else's config and not provided the link to your own.
Kiiavahr
Heya, worked it out sorry.
It will be a gaming rig, I have currently a 2560 x 1440 monitor also.
Budget £2000-2700
2nd M.2 SSD Drive
LED Lighting
Ekans2011
Budget £2000-2700
2nd M.2 SSD Drive
LED Lighting
The link is still missing, but here is a suggestion for your 1440p system.
N.B. The 7800X3D is a placeholder; the 9800X3D is currently out of stock and will increase the price by around £100.
CORSAIR FRAME 4000D RS ARGB MODULAR
32GB Corsair VENGEANCE DDR5 6000MHz CL30 (2 x 16GB)
1TB CORSAIR ELITE MP600 NVMe PCIe M.2 SSD (up to 7000 MB/R, 6200 MB/W)
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR 1200W HXi SERIES™ MODULAR 80 PLUS® PLATINUM V2
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
Firefox™
Price: £2,479.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/NuzfJQn0Bf/
Kiiavahr
Firefox™
Is the Ryzen 7 7800X3D better overall or just for my 1440p set up on that budget?
Also, is this the link you mean?
Ekans2011
Ryzen's X3D chips are gaming CPUs that outperform non-X3D chips.
I don't see the reason to choose a different CPU on your pure gaming system.
Kiiavahr
Can I ask about the power supply you chose? I've never considered one that high before. Is this just a very big safety net or will this make the whole system run smoother?
I've never built my own PC, this is my first (always prebuilt) so apologies for the newbie questions.
Ekans2011
The minimum I'd suggest for a build of that level is a 1000W ATX3, which allows a decent margin for inevitable future upgrades; however, given your budget, I'd go with the 1200W to have an almost unlimited margin if you will upgrade to a top-tier GPU (i.e. xx90) in the future.
