Need help deciding on a case....
Beaker920
Hi folks, I need some help choosing a mini gaming pc case. I like the prodigy, but I would need to get a filter for the side panel. Not keen on fitting it myself. I like the look of both corsair cases, but i know they are not so good at air cooling, so would need a h60 fitting? What Case And method of cooling would you guys recommend?
Ian
sanj
I would suggest the Corsair 380T as it has a huge front case fan and also filters built into the case side panels too, the Corsair 250D is quite good too, both around the same size.
