Need help deciding on a case....
Beaker920
Hi folks, I need some help choosing a mini gaming pc case. I like the prodigy, but I would need to get a filter for the side panel. Not keen on fitting it myself. I like the look of both corsair cases, but i know they are not so good at air cooling, so would need a h60 fitting? What Case And method of cooling would you guys recommend?
Ian
I would personally recommend watercooling in any micro pc case, minimum of H60. Personally, both the cases you point out would be my choices.
sanj
Take a look at the Aerocool DS case's we do,it is a little bigger than the Prodigy but would take a H60 easy and has a huge 220mm fan at the front for good cooling.
