Need fine tuning on gaming PC !
nicknack
Hey everybody
im closing in on the amount needed to buy my new computer so i thought after mix and matching different setups i have come to a result.
i will be using the computer for purely gaming , i wont be overclocking my CPU maybe my GFX card in the future . i have the few questions as if you be kind enough to answer them .
1. is there any point going to a i7 CPU ?
2. will this rig play BF3 on ultra , if not what to i need?
3.would buying 1 SSD drive and 1 HDD drive be worth it or should i just but the HDD drive and the SSD cache , plus is the SSD cache worth the 100 bucks?
4. Getting the 1050 watt power supply a good idea if i want to SLI in the future?
5. Will the tripple copper heatpipe be enough for my needs or should i get the titan for overall performance boost? and if i do pic the titan will i lose the side fan on the CM sniper?
6. left this for last because its not a big issue but which case would be best for my requirments ? the cm sniper ( which i have picked below ) or the HAF-X?:rockon:
rig below, thanks
COOLERMASTER CM STORM SNIPER - NEXT GEN GAMING CASE
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
Free Item
Free Item
FREE Batman Arkham City with any Nvidia® GeForce GTX560 or above!
SSD CACHE DRIVE
20GB INTEL® SSD 311 SERIES - CACHE DRIVE FOR SYSTEM / 1st HDD
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£162)
Sound Blaster® X-Fi™ Xtreme Audio (£32)
REPUBLIC OF IRELAND (£30)
thank you all so much for helping !
mantadog
Superhero Level Poster
Yes, but only if you want the absolute best performance. If you are like most of us and need to keep an eye on the price, then the i5 is a good choice. It will be more then enough to game on for sure.
Not 100% sure. I would be surprised if a 580 was unable to play it on ultra. Only a small percentage of people will have the power of a single 580 in their gaming rigs so i would think that you would be able to. Someone may know on these forums but i'm not sure myself.
In my opinion if your going to have a SSD then you should have windows installed on it + one or 2 of your games. That way you get the really fast startup and loading benefits. Combined with a HDD for storage then it will be really fast. For me SSD's dont make sense yet because they cost too much per Gb. I would rather spend 5 seconds waiting for itunes to open rather than .5 seconds but have to pay through the nose for it.
Yes.
Tripple copper heatpipe will be plenty unless you plan to overclock. I presume you don't so i would stick with your choice.
Also do you need the soundcard? I would stick with onboard as it will be fine for almost everything bar studio music production.
nicknack
thank you for all your input !
If by the time it comes to buying my computer and i can afford the i7 i will get it .
so i should just not bother wasting my money on a ssd cache or ssd cos i dont really mind waiting the extra 5 seconds , all i care about is gaming!
prob will pick the sniper cos its LED are blue and so are my keyboard and mouse , just wanted to know if the haf-x is better wen it comes to SLIing etc?
i have a xfi sound card already on my current PC and i find the sound is way better then my onboard ( then again my onboard is a dell mobo which is prob CRAP!). then again it depends how much my money i have by the end of this month.
i wont be over clocking my CPU ever, so im guessing the tripple copper heatpipe should do the trick ya?
mantadog
A SSD would only load games faster, no in game performance boost. So i would skip it. A few minutes per day extra loading time isn't going to do any harm.
Onboard sound is really good these days as i said above, also if you already have a card, just transfer the card over when you get your pc if you need better sound?
