Need a FireWire port
oimee
Hi - I need to add Firewire to my current set up (bought form PC Spcialist a couple years ago).
Any recommendations for something compatible with this spec? :
THANKS
Case STYLISH BLACK/SILVER TRIDENT CASE + 2 FRONT USB
Processor (CPU) Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
Motherboard ASUS® P8H67-M LX SI (NEW REV 3.0): M-ATX, USB 2.0, SATA 6.0Gb/s, 2 x PCI
Memory (RAM) 8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card INTEGRATED INTEL HD GRAPHICS (HDMI, DVI, 1920 X 1200)
2nd Graphics Card NONE
Memory - 1st Hard Disk 120GB OCZ VERTEX 3 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 500MB/sW)
2nd Hard Disk 1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
RAID NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire NONE
TV Card NONE
Operating System Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (
Frank100
Rising Star
I would think pretty much anything will be fine with it. Just be aware that FireWire B doesn't really work properly with Windows and often speeds will drop down to slightly less than FireWire A. I reckon you can get a PCIe card with FireWire A ports for about £15-£25. FireWire B expansion cards are less common and usually more expensive but like I say you won't see the benefit of the higher speed on a PC.
