I spent a while looking for a laptop because I needed something powerful and reliable for my A-Levels. This laptop, in my opinion, is great value for money and well worth the £935 pounds that I spent on it. Not only is it great for use in my A-Levels, it is great for general use. The keyboard is really easy to use and they keys are firm. The backlight keyboard feature makes it really easy to use it dim conditions and the intensity of the light can be changed with ease. The screen has an amazing picture and the IPS feature which enables you to look at it from sharp angles has really made a difference. The sound bar just below the screen has great sound quality and adds to the great aesthetics of this laptop. This laptop looks really sharp and modern. The only things that I do not like is the mousepad which can be quite difficult to move around so I normally use a mouse that I plug in. Also, the rubbery surfaces look great and feel great but it is quite easy to get smudge marks on them and not very easy to clean. If PC specialist could make a quick guide of some kind for cleaning such a surface, that would be greatly appreciated.
