R0B_
Hi all! Thought I'd post a pic of my new PC from the guys at PCS. Had it for a couple of days now and I'm over the moon! It is a truly awesome piece of kit!
The set up is as follows:
COOLERMASTER COSMOS 1000 SILVER SILENT CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V PRO: USB 3.0, SATA 6.0GB/s, NVIDIA® SLI™, ATI® CrossFireX™
8GB KINGSTON HYPER-X T1 DUAL-DDR3 2133MHz, X.M.P (4 x 2GB KIT)
4GB AMD RADEON™ HD6990 - 1 DVI,4 mDP - DX® 11, Eyefinity 5 Capable
450GB VELOCIRAPTOR WD4500HLHX, SATA 6-Gb/s, 32MB CACHE (10,000rpm)
1200W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (Special Offer) (£149)
COOLIT ECO C240 A.L.C (ADVANCED LIQUID COOLER) (£99)
The CPU is idle around 38 with the fans at 100% RPM
The GPU is idle around 42 with fans at 30%
So far I'm going to add another 2 x 120mm fans to the ALC 240 cooler as it is set up in a pull configuration, I think push/pull will drop it by another 8 degrees easy. The RAM is quite hot and that is what's causing so much heat for the CPU, so I'm installing a fan for that as well.
I was tempted to overclock this rig before I got it, but now that I've tested it out with WoW, Deadspace 2 and COD:MW2 I don't think that will be needed at all... The 2600K and HD 6990 together are more than enough for any game. I will be testing it out on Photoshop CS5 and Maya a little later on as well.
I've also added a 600GB VELOCIRAPTOR HDD and installed Windows 7 to that and using the 450GB as additional and quick storage, or my dual boot with Fedora when they can get the ATI drivers nailed.
Please note that the pic included is looking a little scrappy inside, it was not received like this, I've moved things around to make room for additional components that will be added to the system. The Guy's at PCS did a very good job at cable management till I screwed with it!
