COOLERMASTER HAF 932 FULL TOWER GAMING CASE
Intel® Core™i7 Quad Core Processor i7-950 (3.06GHz) 4.8GTs/8MB Cache
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (3 x 4GB KIT)
1gb gigabyte gt240
CORSAIR 850W TX SERIES (TX850) 80+ ULTRA QUIET PSU (£99)
Sound Blaster® X-Fi™ Xtreme Audio (£31)
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£17)
Monitor
IIYAMA E2472HD 24" LED WIDESCREEN, HDMI/DVI-D HD 1920x1080 (£169)
FAST TRACK 5 WORKING DAY DISPATCH (£39)
Ordered it on the saturday evening. it arrived midday the wednesday which was much faster than i had been expecting. packed amazingly.
i unpacked it , set it up. had a small heart attack when i realised the internal wireless was in the way of adding my gfx card. luckily i had a usb dongle for wireless so i removed the internal and from there on everything went smoothly.
currently running 1920 x 1080 , so far only realy tested on some slightly older games but all run perfectly at full res , most of them run windowed full res while making a system back up , playing music and unraring files. (wanted to see what it could handle at once) and i am impressed. the case is bigger than i expected, had to rebuild my desk around it but was worth it . at some point in the future i will hopefully get a new gfx card and an ssd when funding allows.
Its bin up and running 6 days now. since the first successful boot(after adding my gfx
) not a single problem. every part is exactly what it should have been . does what it should do. arrived quickly and well packaged. and outperformed my expectations.
Not only does it not heat up after prolonged gaming but its actually makes a bubble of cold air around itself.
one very happy customer here, will be reccommending this site to everyone in future.
Thanks to all involved
1gb gigabyte gt240
Monitor
