My new PC and Delivey query
HMellen
What does everyone think of the below build?Also, Currently on 17 working days and getting too eager. I believe the 30 series graphics cards extend the delivery time by quite a lot. Anyone have a rough idea on how long this build could take?
Case COOLERMASTER MASTERBOX TD500 MESH RGB GAMING CASE
Processor (CPU)Intel® Core™ i7 Eight Core Processor i7-10700KF (3.8GHz) 16MB Cache
MotherboardASUS® TUF GAMING B460-PLUS: ATX, LGA1200, USB 3.2, SATA 6GBs - RGB Ready
Memory (RAM)16GB Corsair VENGEANCE DDR4 2666MHz (2 x 8GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
1st M.2 SSD Drive512GB Intel® H10 NVMe SSD + 32GB Intel® Optane™ (up to 2300MB/sR | 1300MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H80i V2 Hydro Series High Performance CPU Cooler
LED Lighting50cm Red LED Strip
Wireless Network CardASUS PCE-AC88 AC3100 2100Mbps/5GHz, 1000Mbps/2.4GHz
Citrus_9
Expert
CaseCOOLERMASTER MASTERBOX TD500 MESH RGB GAMING CASE
I'd cancel this build and get an AMD (read the link below for reasoning).
If you still want to stick with current build, could you give us your full information as per below (second) link (we need to know a monitor, uses and a budget), and include the link to your specs?
MrWilson
With wait times for the 3080 currently sitting at around 100 working days I would definitely recommend cancelling and going with an AMD build.
As above, knowing your uses can also help us refine the build. If you're not gaming with a 4k 144hz or 1440p Superwide such as the G9 you will likely be better suited to a less powerful GPU such as the 3070 which is in much better supply.
HMellen
Thanks Guys, I will cancel and opt for the AMD as this seems to be the best option.
In terms of a monitor I am still looking for one and dont really have a budget so not a massive issue.
Also, using pc for gaming and play pretty much anything. As I said I am quite eager so anything to reduce the delivery time haha.
Thanks again!
Thanks again!
So £1200 for the monitor?
MrWilson
You're going to be in a long wait for the 3080 I'm afraid. The only way to get around the wait is to pay scalper prices elsewhere, which I cannot really recommend. Specced you out a solid gaming build with lots of RGB loveliness. It comes with a 3070 which have been seeing 15 working day turnarounds recently (although this is always subject to change, the issues in the Suez Canal may cause a short term delay for example).
The 3070 pairs nicely with 1440p Ultrawide monitors, and this Acer product will do the job nicely. At £550 it is a little pricier than some other 1440p displays but is well worth it if you've got the budget.
1TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 1880 MB/W)
Price: £2,225.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/usUfDzvdjt/
HMellen
Thanks for the help. This is great!
I shed a tear every time someone buys a 3090 due to the wait. It's a hefty price tag to pay to get yourself along the queue but if you're happy to pay it then fair enough :D
Build suggested with a 3080/90 and a G9 is the stuff of dreams.
HMellen
Thanks again, wouldnt have thought a 3090 would have sped things up that much!
HMellen
Do I have to just cancel the original build all together rather than reconfigure it as when I try to amend my order it doesnt allow me to select AMD rather than Intel?
AimFro
You’d need to call them up to amend that or cancel and reorder :)
