My Gaming PC build.
bragor
This is my first time doing this, i am willing to spend around 1000-1200. any ideas/changes would be very helpful.
COOLERMASTER HAF 922 MID TOWER GAMING CASE
Intel® Core™i7-870 Quad Core (2.93GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55D-E: USB 3.0, SATA 6.0GB/s, CrossFireX™ SUPPORT
1GB ATI RADEON™ HD 5770 PCI EXPRESS - DirectX® 11
2nd Graphics Card
NONE
3rd Graphics Card
NONE
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
NONE
RAID
NONE
2nd DVD/BLU-RAY Drive
NONE
Power Supply & Case Cooling
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£59)
Sound Blaster® Audigy™ SE (£19)
WIRELESS 802.11N 300Mbps PCI EXPRESS CARD (£19)
Modem
NONE, I WILL BE USING BROADBAND
Floppy Disk Drive
NONE
Firewire & Video Editing
NONE
TV Card
NONE
Monitor
IIYAMA E2271HDS 22" LED WIDESCREEN, HDMI/DVI-D HD 1920x1080 (£139)
2nd Monitor
NONE
DVI-D & HDMI Monitor Cables
2 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£16)
Eyefinity / GeForce 3D Vision
NONE
Logitech® Wireless Desktop® MK250 Keyboard and Mouse Combo (£19)
Mouse
NONE
Speakers
NONE
NONE
Headsets (VOIP)
NONE
Surge Protection
NONE
Printer
NONE
External Hard Drive
NONE
Home Installation
NONE
Data Recovery
NONE
FAST TRACK 3 WORKING DAY DISPATCH (£69)
Price (excluding VAT)
£1,002.55
Price
£1,178.00
Order Quantity
Bulk Discount
£0.00
Total Order price (Ex VAT)
£1,002.55
Total Order Price
£1,178.00
bragor
i am open to new suggestions/ Amd builds, i want to play many new games full graphics. World of warcraft, starcraft etc.
Phoenix
Here's an example of an AMD alternative:
COOLERMASTER HAF 932 FULL TOWER GAMING CASE
AMD PHENOM II X4 970 (3.50GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A89TD PRO/USB3 : DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX
1GB ATI RADEON™ HD 6870 PCI EXPRESS - DirectX® 11, Eyefinity 3 Capable
640GB WD CAVIAR GREEN WD6400AARS, SATA 3 Gb/s, 64MB CACHE
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£88)
STANDARD AMD CPU COOLER
WIRELESS 802.11N 300Mbps PCI CARD (£16)
Monitor
Standard Build - Approximately 9 to 13 working days
Price: £1,096.00 including VAT and delivery.
While the CPU isn't quite as good as the i7-870 it doesn't matter too much in games. I've changed the RAM to 4GB because nobody needs more than 4GB of RAM for gaming and you can always add more at a later point for a cheaper price if you start doing other things that need it. The Coolit Eco A.L.C. cooler isn't needed since you're not overclocking and the cheap soundcard isn't really much of an improvement over the onboard HD sound. I changed the wireless card to the PCI type because it's better to use up the older ports on the motherboard and leave the PCI-E ones open for new devices.
With the savings made from these changes I've upgraded the graphics card to the HD6870 which is a much better graphics card that can play all of the newly released titles on high settings, scales well in crossfire and can support up to 3 monitors. I've upgraded the hard disk to a caviar green that's not only larger in size but also performs better which will speed up the system overall. I've upgraded the warranty to silver so that if anything fails within the first year (when most problems occur if they're going to) you'll be covered for repairs. I've also upgraded the power supply to a TX750 which will be able to support a second graphics card and other devices. The motherboard selected supports Crossfire, USB 3.0 and SATA 6.0/GBS which means that it's ready for the future of new high speed devices.
The fast track delivery service wasn't available when I tried to put it into the build, it looks like the case and some other components can't be chosen for it. I would recommend going with either a Phenom II x4 970 build like the one I posted above or an i5 760 build because you can get more out of your budget by not overspending on the CPU.
Tom DWC
The setup Phoenix has put togeather for you looks great. The 6870 is basically a lesser 5870 with moderate tweaks and improvements. It beats the 5770 in the original spec.
