Hello I am going to order a new pc soon and it will be used for playing games such as call of duty, bf3 and minecraft, all of these need to run max settings with no problem whilst lasting a long time (around 3-4 years). These are the specs:
AMD PHENOM II X4 QUAD CORE 970 (3.50GHz/8MB CACHE/AM3)
ASUS® M5A87: AM3+ PLATFORM, DUAL DDR3,SATA 6.0GB/s, USB 3.0
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
STANDARD AMD CPU COOLER
None
None
Quantity 1
So could you guys tell me if this will run as planned and also is it worth it going for the Titan Fenrir Evo Extreme cooler or will the standard one do ok as well?
thanks
None
None
Quantity 1
thanks
