Music Production,gaming sysyem
davieb
Hi all,
Thinking of ordering this rig from pcs.
Mainly using if for music production and some gaming at 60fps .I use a lot of large sample libraries and VST's hence the ssd's and memory.
I'll potentially need 2 spare PCIe slots free on the motherboard (firewire 880 and audio card)
Won't be overclocking but went with the K processor for the faster clock speed.
Budget is around £2300.
Your thoughts would be much appreciated.
Cheers guys.
Intel® Core™i7 Quad Core Processor i7-4790k (4.0GHz) 8MB Cache
FRACTAL DESIGN ARC MIDI R2 MID-TOWER CASE
ASUS® Z97-A: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
32GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (4 x 8GB)
4GB NVIDIA GEFORCE GTX 980 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
1st Hard Disk
500GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
1TB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
3rd Hard Disk
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (£69)
3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour) (£69)
Price: £2,337.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-haswell-pc/CevekdZjNv/
GeorgeHillier
How about this?
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-4790 (3.6GHz) 8MB Cache The k version won't give you noticable increases
Case CORSAIR CARBIDE SERIES™ 200R COMPACT GAMING CASE
Motherboard ASUS® Z97-A: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
Memory (RAM) 32GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (4 x 8GB) Do you need 32GB? I put it in there because you said you need it
Graphics Card 4GB NVIDIA GEFORCE GTX 980 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
2nd Graphics Card NONE
3rd Graphics Card NONE
1st Hard Disk 1TB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW) Large SSD
2nd Hard Disk 4TB WD CAVIAR BLACK WD4003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) Large HDD, using SSDs to hold libraries is very very expensive and would advise against it
3rd Hard Disk NONE
4th Hard Disk NONE
RAID NONE
M.2 SSD Drive NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Processor Cooling Corsair H55 Hydro Series High Performance CPU Cooler I would suggest a water cooler if using it as a workstation as well, will keep it nice and cool while working
Extra Case Fans 2 x 12CM Black Case Fan (configured to extract from rear/roof)
Fan Controller NONE
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
USB Options MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Firewire NONE
TV Card NONE
Operating System Genuine Windows 8.1 64 Bit - inc DVD & Licence
Windows 10 Upgrade FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases
DVD Recovery Media Windows 8.1 (64-bit) DVD with paper sleeve
Office Software NO OFFICE SOFTWARE
Monitor NONE
2nd Monitor NONE
3rd Monitor NONE
4th Monitor NONE
Monitor Cables NONE
Eyefinity Adapter / GeForce 3D Vision NONE
Keyboard & Mouse NONE
Mouse NONE
Gaming Mouse Pad NONE
NVIDIA SHIELD™ NONE
Speakers NONE
Webcam NONE
Headsets NONE
Surge Protection NONE
Cable Tidy NONE
Printer NONE
External Hard Drive NONE
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
Home Installation NONE
Build Time Standard Build - Approximately 4 to 6 working days
Pricing Information
Price (excluding VAT) £1,578.33
Price £1,894.00 A lot cheaper, mostly because of the HDD, so worth taking a look at
davieb
Thanks for your input George,
Changed a couple of things.
Caviar black 2tb as the 3rd hdd use for audio and some VST's
Some of my sample libraries use disk streaming so need 1 large ssd and smaller ssd for OS and apps
Also changed to Win7 pro as some of my audio gear isn't compatible with 8.1 yet.
There's isn't much difference in price between the k and non k processor but higher base clock speed so I thought that might be a better option?
I heard water coolers can sometimes be noisy and wont be overclocking?
Updated spec:
1st Hard Disk
3rd Hard Disk
2TB WD CAVIAR BLACK WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence (£109)
Price: £2,084.00 including VAT and delivery.
