MSI Radeon R9 380 ?
sampat
Case COOLERMASTER CM690 MKII ADVANCED CASE
Processor (CPU) Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
Motherboard ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card 2GB AMD RADEON™ HD6950 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk NONE
RAID NONE
SSD CACHE DRIVE NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Processor Cooling SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Fan Controller NONE
Sound Card Sound Blaster® X-Fi™ Xtreme Audio (£32)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Have added SSD and now have 16g of ram, could my rig as it is run the R9 380 as it stands ? and is it worth the upgrade over the 2GB AMD RADEON™ HD6950 it as now ?. Thank you
do you have a budget for your gpu upgrade? the psu is good enough to support the R9 380
