hobbes1218
Hi folks, since I received my PC from PC Specialist a year ago I it has not managed more than a month of error free operation. After the first month it started to turn itself off randomly or not turn on. If left, it would eventually turn on – sometimes after a delay of several hours. After several months of this, the problem became more frequent so I called PC Specialist who told me to take out the battery for 30 seconds. This actually worked – but only for a month or two. After that taking out the battery made little or no difference. I sent the PC back and received a short report back from PC Specialist that the log was showing Kernal 41 errors and they had updated some drivers. The PC was working fine again but only for about another month and then the switch offs started again. I had turned Windows updates off to try and prevent any further problems but that obviously didn't help. This morning after another shutdown the screen has now started to freeze as well.
I will call PC Specialist again but think it likely that I will be told it is a software issue. Before I do this I wonder if anyone has any thoughts about what may be the cause of the problem? What can be the cause of Kernal 41 errors? If there is a driver conflict why does this only cause a problem over time with increasing frequency? If there is a problem with the software stack on my PC wouldn't PC Specialist expect to have seen the same problems with other PC's that they built around this period?
I really don't want to reinstall Windows if I can avoid it + if I did I would just end up with the same software stack so I assume I would be very likely to run into the same problems again. If anyone has any thoughts – anything I can check please let me know.
System spec :-
Processor (CPU) AMD PHENOM II X4 955 (3.20GHz/8MB CACHE/AM3) - BLACK EDITION
Motherboard ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card 1GB NVIDIA GEFORCE GTX460 GDDR5 PCI EXPRESS - DirectX® 11
Memory - 1st Hard Disk 500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
Power Supply & Case Cooling CORSAIR 650W PSU (TX650) 80+ ULTRA QUIET
Processor Cooling SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence
Cheers, Chris
System spec :-
Cheers, Chris
