Monitor for this spec?
markdienekes
I was wondering what sort of monitor would work on this spec?
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-4590 (3.3GHz) 6MB Cache
Case InWIN GT1 BLACK GAMING CASE
Motherboard ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
Memory (RAM) 8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
Graphics Card 4GB NVIDIA GEFORCE GTX 970 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
2nd Graphics Card NONE
1st Hard Disk 250GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk 1TB WD CAVIAR BLACK WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st PCI-E SSD Drive NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 550W VS SERIES™ VS-550 POWER SUPPLY
Will a VGA monitor work? At the moment I was hoping to get by on my old one (a Dell E228WFP 22") but asn't sure if it would fit the set up, so am looking to buy something else. Am I right in thinking it's to do with the motherboard? (So in this case I'm looking for something with HDMI & DVI?) Thanks for your time.
Utilize
They provide a DVI to VGA adaptor with the graphics card but you might be bottlenecked by the monitor. What resolution is it?
markdienekes
The Dell one is only 1680x1050 - but I've got a £50 amazon voucher and can add about another 30 on top of that (so around 80). Was thinking of the Asus VS228DE, the Acer S220HQLBrbd or the Samsung S22D300HY. Just found a Asus VE228TR which is tem;pting me the most, what are your opinions of it?
Utilize
Any of them would be fine really, have a look at some reviews and see anything jumps out.
