Monitor compatibility issue to my new build + purchase advice
Kvothe
Hi, i suspect this might make me look bit silly, but after purchasing new gaming build, I realized my current monitor is likely too old for connecting to my new case/graphic card in any meaningful way. My monitor has the DVI, VGA and HDMI ports only (no DP port). The new hdmi cables I have (although they fit both ports to case and my monitor) don't do anything and monitor doesn't display a thing - remains dark (it is in great working order otherwise, in my current poor elderly build).
I'm wondering if anyone has a suggestion whether it's possible to connect my asus vg278hr to the build (please see below) in a way that is reasonable. As I suspect this is not an option, my second question is what would you recommend for a new monitor to my build (budget: 800 +/- 100; but prefer bit cheaper if possible without compromising performance much according to what my build can do)? Happy to pay the higher end of my nudget if it's one of those super wide monitors. Many thanks.
My build:
CaseCOOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE
Processor (CPU)AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
MotherboardASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 8GB)
Graphics Card6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
2nd M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Processor CoolingCoolerMaster MasterLiquid Lite 240 High Performance Liquid Cooler
LED Lighting50cm ARGB LED Strip
Windows Recovery MediaWindows 10 Multi-Language Recovery Image - Supplied on USB Drive
DeliverySCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Build TimeStandard Build - Approximately 10 to 12 working days
Change to: FAST TRACK 3 WORKING DAY DISPATCH
Kvothe
Are you sure you're plugging into the graphic card and not the motherboard
yes (did the mistake in the past), there are 3 dp ports and 1x hdmi port available where the graphic card is attached. the hdmi in the area of the mother board is actually sealed off. I also thought about whether those cables I bought are simply wrong for this, but I don't know if that is the case. When I try those cables and switch the new PC on, the monitor just displays text: 'no DVI input'. I think it's just the monitor not being up for this?
Cables I tried: 1. 4K HDMI Cable 1M HDMI Lead/cord -Snowkids Ultra High Speed 18Gbps HDMI 2.0 Cable 4K@60Hz for TV/4K TV, 3D, Blu-ray player,with Ethernet Function,Video
2. Amazon Basics High-Speed, Ultra HD HDMI 2.0 Cable, Supports 3D Formats and with Audio Return Channel, 0.9 m
Yeah it maybe that it isn't upto it, also check the gpu is properly seated.
@SpyderTracks is the guy whose really good on stuff like this
It sounds like it's on the DVI channel rather than HDMI, just change the input channel?
