HI ,I have a Playstation 3 and a midlle to high end P.C.Now I am looking to invest in a new monitor which will both enable me to play the PS3 and the P.C.Obviously,[or is it?] I would need the monitor to have a HDMI socket.Now I have been trawling the NET and at a price that is in my budget ,they are hard to come by.My budget is up to 136 but preferably as cheap as possible.Any advice as to what monitors would fit the criteria I have laid out would be appreciated.Any thoughts are welcome and thanks in advance,.I am curently trawling the Interenet but have only come across one suitable candidate .As the capability to use this monitor on both formats is paramount any other considerations have been put to the back of my mind though I would stil like the qualities of the monitor to be such as to make good for gaming primarily.
I have another question.Is there a way of getting sound with the use of a DVI to HDMI convertor cable,[example],I once plugged in my x box 360 to one of my monitors via the aforementioned cable and obviously got no sound,image yes,sound..NADA.Is there any technique around this problem apart from having the nonitor HDMI capable.
I came across one monitor on the scan.com site which fit the bill in terms of HDMI capability[unsure whether it is actually a good gaming monitor as I am unable to locate any reviews./the monitor is the Viewsonic VX2239WM 22",LCD Monitor,[price/136 ,including vat] on scan , the LN number is LN 36525
If anyone can comment on this model or generally offer advice please do not hesitate to,Thankyou for reading,greybing.
