TravelSite
I received my new PC on Friday evening. It worked fine that evening and I ran microsoft update to download all the latest updates, restarted it to make sure everything was fine, then shut down the pc (it was on for about 5 hours in total).
I then went on holiday for a few days and on returning can't seem get it to work.
It kept showing a missing operating system message.
I can get into the BIOS by pressing the Del key - but that's about it. Both the hard drives do appear in the bios (though I'm not sure what settings to check for - but the raid 0 seemed to work okay initially)
I've also loaded the Win 7 disc and selected Startup Repair - but it says "Startup Repair cannot repair this computer automatically". I also can't run the "Windows Memory Diagnostic" as it I get a message stating "Windows cannot check for memory problems. An error is preventing Windows from checking for memory problems during startup".
Any advice on what to do next? Is it okay to re-install Windows 7 afresh (given that there isn't any data on the drives yet)? If doing so will I need to configure it for RAID 0 myself (twin Kingston 250GB ssds) via the bios?
